![Bang Head :head:](./images/smilies/banghead.gif)
glass stains
glass stains
I have some sheets of glass which have water marks in them,is it a fault within the glass or the surfacet as i have tried everthing to try to wipe them clean......anybody got any ideas on the matter. ![Bang Head :head:](./images/smilies/banghead.gif)
- Organisation: Dordogne
- Interests: Food, cooking or eating
Re: glass stains
If the 'watermarks' you're referring to are on 'Papered Float' Glass, I have found that the normal glass cleaner doesn't clear them.
The most effective way I've found is to spray the suface with very weak water/washing-up liquid and then use a small amount of Cif on a cloth, spray with the water mix again and wipe off. I then finish it off with the glass cleaner and Robert's your Father's Brother!!
There's probably some other way of doing it, but this works for me....![Giggle :giggle:](./images/smilies/emoticon-0136-giggle.gif)
Re: glass stains
I've just started using Lion's glass cleaner concentrate (ref 979).
Brilliant stuff!
Shifts all those paper marks and lots else besides. By far the best glass cleaner I've tried so far.
Brilliant stuff!
- Organisation: framejunkie
- Interests: 6.9%APR; 21.3%APR
Re: glass stains
This is my preferred glass cleaner also. I recently started to use de-ionised water to dilute it, having always just used tap water. I found it a help - fewer streaks so less elbow grease required.WelshFramer wrote:I've just started using Lion's glass cleaner concentrate (ref 979).
Brilliant stuff!
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Re: glass stains
I use pH neutral Welsh spring water.
Probably has much the same effect as de-ionised water but in our case it comes out of the tap.![Very Happy :D](./images/smilies/icon_biggrin.gif)
Re: glass stains
Do you know the mineral content of the tap water? Its primarily the calcium that causes the streaking, apparently.
London water is
35% Bleach
26% chalk
4% sewage
34% H2O
1% orang-utan's tears(they're crying about the ramin trees)
London water is
35% Bleach
26% chalk
4% sewage
34% H2O
Re: glass stains
LOL!
best to stick with the beer then!
I use 0000 steel wool (use dry) to get rid of the ‘water marks’ then clean as normal. Works a treat.
