Keencut Glass Cutting
John
Site Admin
Organisation: Tech Support
Interests: Forums and stuff
Post by John »
When cutting a few millimetres from a piece of glass, instead of scoring the line and nibbling with your grozing pliers, an alternative method is illustrated below: -
After scoring, place a solid wooden straight-edge on the overhanging sliver.
Apply a sharp blow with the lower hand while applying firm pressure with your upper hand.
With practise you should be able to remove a 2mm unbroken sliver from a full sheet of glass using this method.
less
Glass cutting
Post by less »
a good tip I'm sure but shouldn't that young lady be wearing gloves? If she had ever seen serious glass cuts I'm sure she would always wear them!
Regards
Les Sutherland aka less
John
Site Admin
Post by John »
Gloves, you say!
Next you'll be wanting her to have the weekends off, teabreaks, etc., where will it end? :?
