For Sale C+H Pro 48” mat Cutter and Brevetti Under Pinner
Posted: Wed 14 Oct, 2009 12:34 pm
“The Nielsen & Bainbridge C+H Pro 48” Professional mat Cutter–Precise, Smooth, easy to use and Delivers Perfect Results first time, Every time.”
“The Brevetti Delta-e Pro Electric Joining Under Pinner–At 100 Frames per hour all you can hear is the Noise of the V pin Being Driven deep into the Moulding.”
So what makes Brevetti the best joining machine maker in the world? “There is really no mystery to it–we balance precision engineering and performance with deep customer knowledge, value and attention to detail,” said Bruno Viscontti an eminent Brevetti engineer.
Item 1: Nielsen & Bainbridge C+H Pro 48" Professional Mat Cutter–if your looking for years of truly uncompromising performance with every cut this precision engineered cutter is easy to use, ergonomically shaped, Teflon coated, fully calibrated–designed for Stanley blades–with an overcut indicator on the head assembly window gauge for accurate depth and adjustment. The C+H Pro 48” gives a professional finish and provides smooth and responsive handling through its main bar/rod assembly which is uniquely bow shaped to clamp the mat in place along its entire length to give perfect results in seconds, every time–cutting down on costly mistakes and wastage. In great condition, this C+H Pro 48”comes with production stops and an inbuilt overcut indicator to eradicate over cuts and undercuts, squaring arm, original owner's operating manual and parts list. The Nielsen & Bainbridge C+H Pro 48" Professional Mat Cutter currently retails at £800 plus VAT.
Sale price, a bargain at only £150.
Item 2: Brevetti Delta-e Pro Electric joining under pinner–In superb condition and working order the Delta-e produces a phenominal100 frames per hour–providing a huge return on your investment–with its powerful, silent 220V motor. This sturdy 40 kilo, pneumatic table top joining machine is fully automatic, completely silent, fully adjustable and is electric foot pedal operated, leaving both hands free to work–hand crafted by the world’s leading Italian innovator in joining frames. The all electric Delta-e is ideal for producing any shape frames or moulding profiles from 4mm up to 120mm in width and up to 70mm deep–including curved. Inbuilt safety features such as the emergency stop button and thermal relays avoid overheating and ensure safe, trouble free production around the clock. The Delta-e can drive up to 3 stacked V nails deep (from 6 to12mm nails) into any moulding profile (hardwood or soft) and has an inbuilt stroke stop regulating mechanism to prevent any damage to delicate mouldings. There is also no need for a separate, expensive, noisy air compressor. As an added bonus this Delta-e comes complete with a FREE heavy duty steel mobile trolley on rubber casters with brakes worth £130 and the original operator’s manual. Equivalent set-ups currently retail at £1,200,00 or more.
Sale price, only £350.
Genuine reason for sale. We are located in Surrey. As both your and our time is valuable, only serious cash buyers–ready to buy now–looking for quality, performance and professional results need call. No re-sellers please.
Call Paul today on 07503 512 485 or E-mail paul.guiste@gmail.com. Both machines are offered strictly on a first come first serve basis.
