We do not have a POS software system, but use a spreadsheet. It greatly simplifies the arithmetic, but you can use the principle with a pencil and paper as well.
We determined how much to charge for a particular procedure by using a stopwatch and timing how long it took to stretch, say, a 16 x 20 inch (36 united inch) piece of needlework then a 22 x 28” (50 united inch). Once we got that time, (lets’s say it took 25 minutes to do the 16 x 20 and 34 minutes for the 22 x 28”) we did a regression equation i.e.
25 = 36x + y
34 = 50x + y
If we subtract the two we get
34 = 50x + y
-25 = -36x - y
or, 9 = 14x
or x = 9/14 = 0.6428
Plug that 0.6428 into either of the initial equations (lets use the 50 UI one) and we get
34 = 50 times 0.6428 + y
or 34 = 32.14 + y
or y = 34 – 32.14 = 1.86
so for any united inch between 18 and 100 we can figure out the time as
time = United Inch times 0.6428 plus 1.86.
Once you have the time it requires to stretch a certain piece of any size, multiply that by your shop fee and you can get how much you should charge.
The above example is strictly labor. It does not include materials such as needleboard or stretcher/strainer bars. Those are completely separate charges in our shop and are a combination of a materials mark up and a labor charge to cut the material to size.
