WANTED - MOUNTBOARD STORAGE/WORKBENCH
Posted: Sun 14 Mar, 2010 9:09 pm
by shepherdn
I am looking for mountboard storage / workbench - please let me know if you have anything that might be of interest
Re: WANTED - MOUNTBOARD STORAGE/WORKBENCH
Posted: Sat 17 Apr, 2010 12:48 pm
by dougie
same as a reply i gave to another question,did mountboard storage using slat wall and 9mm mdf,you put the slat wall top and bottom and the mdf fits nicely into the slots you have,you can put thicker mdf on the sides and another top on if you want,works well for me and i get 40 or so sheets in each compartment
Posted: Sat 17 Apr, 2010 3:23 pm
by Dev
Dear shepherdn,
Why don't you try following supplier-
LION PICTURE FRAMING SUPPLIES LTD
BIRMINGHAM
http://www.lionpic.co.uk
They have a nice award winning mount board storage system.
Please do visit their website for more details.
Dev
Posted: Sat 17 Apr, 2010 5:26 pm
by John
A Helpful first post Dev.
Welcome to the forum.
Posted: Sat 17 Apr, 2010 7:14 pm
by Grahame Case
John wrote:A Helpful first post Dev.
I would like to be associated with the above comment, Welcome to our happy community Dev.
Posted: Sat 17 Apr, 2010 8:00 pm
by Merlin
Welcome to the Forum Dev.
A clever idea. Might just use that on the next rebuild
Posted: Sun 18 Apr, 2010 8:36 pm
by NorthernTracey
I'm gonna be selling up soon and have a Lions mount storage unit. Let me know if you're interested. I'm in North London (Hertfordshire).
Posted: Tue 20 Apr, 2010 5:15 pm
by shepherdn
Thanks for all your advice - definitely going to try the slat wall idea - sounds perfect
Posted: Tue 20 Apr, 2010 7:52 pm
by fraggle
Hi, also looking into this
Can you explain a bit more on the "slat wall" design idea?
Also, what has worked best for everyone as a workbench top, realise that I asked that in my first ever post but this may be a more relevant place to ask
Fraggle
Posted: Tue 20 Apr, 2010 8:25 pm
by Roboframer
I've never liked the idea of open storage under a workbench - too much activity and therefore risk of damage to stuff poking out, or even flush; not to mention tripping hazards.
Remember the people selling these things realise they take a lot of space - so they plug them as dual-purpose - and so they should be, why waste that space! But in a lot of workshops they need to be workbenches as there isn't enough room for a dedicated 'bespoke' bench.
The bench you work all day at should be the right height for you otherwise you can develop back problems and these storage units (I have two but they don't double up as a workbench) are built to cater for mount board size; not your height. I put 6 days a week around my workbench and at my age if it was wrong I'd be feeling it by now.
A good guide for the correct height of your workbench - bend over until your back is parallel to the ground - the distance from the top of your shoulder to the ground is about right for the height of your bench.
Then you need to watch the height of any employees you take on!
Posted: Tue 20 Apr, 2010 9:33 pm
by John
Optimal workbench height is considered to be 50-100 mm below elbow height, so benches that can store standard sheets of mountboard should be OK for most people. However we are all different, whatever you are comfortable with is right for you.
We have a self-made 8 x 4ft bench which can be walked all around, it is raised off the ground a couple of inches to give toe room and has 20 bays/slots for storing mountboard. We all, ranging from 5ft-5in to 6ft, find it quite comfortable to work at. Well, no complaints so far. :)
Posted: Tue 20 Apr, 2010 9:40 pm
by Dermot
Scroll down this http://www.ccohs.ca/oshanswers/ergonomi ... basic.html from the safety/ergonomics at work people in Canada, there is a good giude to workbenches,
Posted: Wed 21 Apr, 2010 8:11 am
by dane
Hello,
I wondered if you'd got fixed up with the bench you were looking for ? I have a custom built unit in storage as I no longer have the space to use it. It fits against a wall, slopes for easier cutting and has storage space underneath - 3 or 4, I forget which - slide in from the side
spaces where I kept 2 different kinds of glass and mdf - full sheets so would obviously take mountboard with ease. The top was big enough for
a 4x3 sheet of glass plus. It's made from square section steel and bolts together - the top is blockboard and was carpeted.
If you're interested I'll find time to photograph it. I'm in S. Yorkshire 10 mins from the M18 Doncaster exit.
Posted: Wed 21 Apr, 2010 8:56 am
by Jonny2morsos
If you do go the slatwall route get it from Jazolo in Northampton. You won't find it cheaper anywhere else.
It comes on a pallet dropped off a lorry so make sure you can accept their delivery. Driver was not too happy about getting the pallet truck across the gravel in front of us. It is also very heavy so make sure you have some help when it arrives.
Posted: Thu 13 May, 2010 1:35 pm
by fraggle
Thanks for all the info
My handy hubbie has found some old slat wall at his work place (he is a manager at a garden centre) so I have something temporary to get started with
I have just measured and sketched my worktop layout - eek! Nearly there, then I can start buying the goodies to practise with
Fraggle
Posted: Thu 13 May, 2010 1:39 pm
by fraggle
I meant to ask you all what internal storage space you need for the mountboard?
The sheets seem to come in 44" x 32" but do you need a couple of inches clearance above them for easy access so you don't "ding" them when moving them in and out?
Once you have added "toe space" below + thickness of work top you are probably up to about 36" - would that be right?
Fraggle
Posted: Fri 28 May, 2010 8:41 pm
by fraggle
I just wanted to say that my slat wall based storage bench is nearly done - just need to add the worktop and the cosmetic trimmings.
Thanks for all the tips.
And.....in case you wondered.......it is the correct height too!
:D
fraggle
Posted: Sat 29 May, 2010 8:28 am
by Phill
Any chance of a photo Fraggle, it is such a great idea, well done Dev :clap:
Posted: Sat 29 May, 2010 1:39 pm
by fraggle
I will try and sort some photos at some point - if I can work out how to post them! :?
Posted: Sun 30 May, 2010 8:40 am
by WelshFramer
Roboframer wrote: Then you need to watch the height of any employees you take on!
Just employ tall ones and wear them down till they're the right size.
