Calling all photographers. Practical advice needed.
Posted: Tue 03 Jan, 2006 9:53 pm
I know that my 'visualised' framing jobs could be enhanced considerably by improving the quality of the subject image. But how do I go about this?
The camera is mounted on the ceiling 2m above the counter which is quite brightly lit by 'daylight' fluorescent fittings.
If the subject has a mat finish, the image produced using the ambient light is OK (but not great), however if it has a slight sheen then reflections from the fluorescent fittings start to become apparent. And if the subject is glossy, I can just forget it.
My plan is to angle two lights, positioned on either side of the camera, so that they illuminate the counter at (say) a 45 degree angle.
Is this the right approach, and what should I use? I feel that tungsten lamps might not be powerful enough to "drown out" the reflections, so am leaning towards flash. But I have no experience in this area. What sort of units can be left at the ready , being fired intermittently perhaps 20 times a day? Would diffusers of some kind be required? (I would also like to keep the setup as inconspicuous as possible, so small is good, tiny is even better.)
Any advice greatly appreciated.
John
John
