Laminated Maps
Posted: Mon 19 Apr, 2010 10:04 pm
by master
I have been asked to frame four large laminated maps in such a way that pins can be inserted to mark towns and villages etc.Any ideas how I might do this? Thanks.
Re: Laminated Maps
Posted: Mon 19 Apr, 2010 10:05 pm
by stcstc
never done it, but what about mounting it on a cork board, then framing without glass
you could cold press it down to the cork
Re: Laminated Maps
Posted: Mon 19 Apr, 2010 10:27 pm
by mikeysaling
i have also used insulation board for this - available from hardware places like travis perkins ! check it out .its great for pinning things to.
Re: Laminated Maps
Posted: Mon 19 Apr, 2010 10:33 pm
by ahohen
I have done it with regular glass over the map (spacer between the glass and laminated map). A permanent marker was used on the glass. To remove it they simply scrape it off with a razor blade. Temporary marker can also be used that will just wipe off with a paper towel.
Re: Laminated Maps
Posted: Tue 20 Apr, 2010 7:46 am
by absolute framing
Previously we have glued the laminated map to sundela notice board using PVA
http://www.sundeala.co.uk/
I sandpaper the back of the laminated map to help the PVA bond to it.
The Board is then fitted into a suitable frame,
Re: Laminated Maps
Posted: Tue 20 Apr, 2010 6:58 pm
by Dan
If they are going to be pulling the pins out and moving them make sure they know the map will not heal and the insulation board would be best to use. I am not sure if you have any board from Gelman Brothers from GIlman CT in the USA. THey offer a "Magnet Receptive" board. You could nount the map on it and then use magnets on this. THat way if they plan on moving the pins you would use magnets instead and not leave holes from the pin.
Dan
