Arqadia Moulding 735 101 000
Posted: Thu 29 Apr, 2010 12:38 pm
by JamesC
Anybody got any of this moulding they don't need? It's a smooth matt black box style 22mm wide 30mm deep.
It's out of stock till July 26th and I use a lot of it, despite the fact it's not nice to cut it's a stylish look for the price.
Ideally I'm looking for a 100m box of it. Otherwise I'm going to have to change it and get bits of my website redone etc. which I could do without and is expensive.
Checked Simons and they don't have anything very similar. I could probably get away with a very close substitute and would even pay a bit more just to cover the gap.
Problem is Arqadia's close alternative is 235 101 000, nicer to cut but £3.99 a metre for a simple black moulding! I've tried some of it and it's not even that well finished to attract a premium i.e. blobs in the lacquer and scrapes in the wood on the sides. The other is 225 167 000 at a more reasonable £2.15 a metre but this is quite a bit shallower and not as impressive, otherwise I would be using it already for the ease of cutting on a guillotine. It really needed to be at least 28mm deep and 21mm wide.
Anybody else had or solved this problem with a different supplier? I scrounged a box of it at Xmas but Arqadia have only had this moulding for about 2 weeks in stock in the past 7 months! Unfortunately they only sent me a 12 bar back order not the box I tried to order later during those 2 weeks hence this predicament.
The replacement has to be smooth matt or satin really, don't like the grainy blacks they look dated to me and not what I advertise.
Re: Arqadia Moulding 735 101 000
Posted: Thu 29 Apr, 2010 12:50 pm
by JamesC
Quick correction - it's only out of stock till July 12th when I just looked but still in need.
Posted: Thu 29 Apr, 2010 2:07 pm
by Jonny2morsos
Have you tried Frinton Mouldings? Might be pricey but woth a look.
Posted: Thu 29 Apr, 2010 2:19 pm
by wrxsti555
HI James.
Have in stock a 20mm wde 30mm deep matt black. Ref no. SB/I/268. Very slight curved top.
Have about 100 mts in stock with further 300 mts arriving in next two weeks.
Box price £2-50 mtr. Can send a sample if required. Tel Shaun @ Ventons 01579 389310.
Posted: Thu 29 Apr, 2010 4:17 pm
by robbiez
Posted: Fri 30 Apr, 2010 1:12 pm
by BaBaZa
I've posted a sample of our 007 1101 @£1.49/mtr
Posted: Fri 30 Apr, 2010 7:30 pm
by mikeysaling
hi cannot find my post about a particular arqadia moulding - have now registered - how do i find the stock position of the moulding??
Posted: Fri 30 Apr, 2010 8:21 pm
by Roboframer
find your moulding and click on 'more information'
Posted: Sat 01 May, 2010 7:53 am
by mikeysaling
great thanks robo - found the stock - but odd the website doesn't confirm im logged in! and i wonder how you log out? stll its the stock im watching so thats ok.
Posted: Tue 04 May, 2010 5:37 pm
by Framerpicture
Try Midas is your looking for that sort of quantity. Although i don't have a sample in front of me sounds like 384 Black
Posted: Wed 05 May, 2010 3:40 pm
by JamesC
Got sorted with the Mainline mouldings number.
I can recommend this company who I hadn't come across before - the website was modern, easy to use and to see the range, they got a sample to me dead quick, did me the box price on 24m so I could see the quality, came next day really well packed.
The lengths of this black are a little bowed in places but should be fine to use and once taped to the backboard as I do - not twisted at least. The general finish is good and the black clay not as thick as the Arqadia one which makes it a bit nicer to cut without crumbling. I'm just sacrificing 2mm in width but gaining 3 in depth.
