My customer wants me to frame her piece of embroidery, but she wants it padded (Raised) from behind. Can anyone advise me as to how best to go about this.
What padding material do I use and how do I secure the edges of the embroidery to the back panel.
Alan
Mounting Raised Embroidery
nala2247
- Organisation: Cape Town
- Interests: Photography
Dermot
Re: Mounting Raised Embroidery
Have a look a Mal Reynolds methods of framing fabric pieces he is a real master at this sort of framing.
http://www.harlequin-frames.co.uk/articles.htm
The padding is called batting or wadding you can get a pure grade from PEL but depending on the item you are framing what you can get in your nearest fabric shop may do.
http://pel.eu/Store/Products/Conservati ... nd-Wadding
If using a window mount, only pad the aperture, less a fraction, this will give a 'cushioned' look - the thicker the wadding the more effect - then you'll need to make sure you don't lose that effect by having the glass against it.
As for securing - as long as you have enough spare fabric around the piece then lace it, if you don't have enough spare fabric then extensions could be sewn on.
