The copper sheet (200mm x 200mm x 1.2mm) had to be float mounted on mountboard, with a floating effect of about 5 to 10mm. I cut the backing mountboard (375 Colourmount), and the 6mm MDF back. I cut four blocks of obeche fillet, 9mm x 40mm x 40mm. The outline of the copper sheet was drawn in pencil on the MDF, and roughly where the wooden blocks would be positioned. I drilled a hole through each block and the MDF for the fixing screw. The rough position of where the epoxy adhesive would be was also marked (about 15mm diameter) all around this area very small holes were drilled, these 'vent' holes would make it easier to reverse the adhesive bond in the future. This can be done by fuming or by careful direct application of the reversing solvent into the holes.
I then weighed out 20g of Paraloid B72 acrylic resin pellets, these were put in a glass bottle with ml measurements marked on the side, then acetone was added until the level reached the 100ml mark. This gives a 20% W/V mixture. This was left overnight to dissolve, and after shaking and mixing well an even coating was applied to the back (which I first sanded lightly to give extra 'tooth') of the copper sheet, where the four glue points would be, and also to the four wooden blocks. This was left for 24 hours so the acetone could fully evaporate before a second coat was applied, and then left for 48 hours.
The copper sheet was then ready to be fixed to the four wooden blocks. For this I used Araldite 2015 epoxy adhesive, which is a toughened high strength adhesive paste. A blob of epoxy was applied on the four wooden blocks and a weight was placed on the copper sheet while the adhesive cured. In practice I think I used a little to much epoxy, I was aiming for a 15mm x 0.5mm layer between the wood and copper, but it spread a bit further out than this.
To remove the piece in the future, the four screws would be undone, leaving the four wooden blocks fixed to the back of the copper, these and the epoxy fixing them could be removed by reversing the Paraloid barrier layer with acetone, toluene, or xylene.
The benefit of this method is that there are no visible fixings, the long term strength of Araldite is well known, as is the stability and conservation suitability of Paraloid. I think this method would be suitable for framing various objects such as tiles, plaques, where a stable, long term, but reversible bond is required. I think it would be particularly suitable for mounting tiles and other stone type objects. I know this method will not appeal to everyone, but I think it could have its uses.
In a few weeks I plan to take the frame apart, and attempt to remove the four wooden support blocks from the copper. Theoretically it should be possible to totally remove and reverse the adhesive barrier layer, so I will post how I get on doing this!
