Kit - standard size gunner f1 max sheet size 1200mm x 900mm 47" x 35"
bit of advice chaps.
Looking around for some mountboard now.
I need to get as many 8x10" size cuts of a single sheet . whats the best size of sheet to go for ?
Seems to be a few diff sizes of sheets out there.
Many thanks.
gunner f1 mountboard size.
upload
- Organisation: alloa
- Interests: movies
always look an the bright side of life...
- Tim
- Organisation: Deepwell Framing
- Interests: Photography, Growing it, Cooking it, Eating it. Sauvignon Blanc. Syrah.
Re: gunner f1 mountboard size.
Anything over 1016 x 813 will get you 16 mounts from a sheet.
So most standard Colourmount board should be ok. Note : Some of the linen boards are only 800x1020. All the Conservation and standard White core are 815 x 1200.
Hope this helps
Tim
Hope this helps
Tim
stcstc
you cant cut bigger than 850 by 1200 so whatever you can get out that size
