oversize mount(matt) cutters
Posted: Mon 23 Feb, 2004 1:25 am
by stafford
dear members,
can anyone advise me about an oversize mount cutter.
i currently use a fletcher 2100 but even their biggest is not big enough.
every week i am asked to mount oversize images from the likes of king mcgaw, nouvelle image and many more.
i am not prepared to use a freehand cutter as i demand of myself a very high standard, and the models i have tried are not up to this.
i am based in the uk and have contacted everyone here inc fatg and professional manufacturers.
yours
stafford
Posted: Mon 23 Feb, 2004 9:45 am
by Guest
Stafford
I have sent the link for this forum to John Ranes who has his own framing in the US….he is also a consultant for “The Fletcher Terry Company”…..John spends over a 100 days a year travelling the world for Fletcher…..and is very familiar with the framing business in this part of the world…….he is in Italy this week (I think) at a framing exhibition…..I suspect he will be able to come up with a practical solution for you.
Rgs
Dermot
Posted: Mon 23 Feb, 2004 9:52 am
by Dermot
Oh oh…..I need to figure out how to respond as myself or I just come up as a guest poster………right another job….to tackle….
Rgs
Dermot
Edit by Dermot
Got it I just need to log on to the forum.......
Posted: Mon 23 Feb, 2004 3:49 pm
by John
Although we now use a Wizard (Computerised Mount Cutter) which will handle up to 40 x 60in, for many years we cut large mounts on the floor of the shop using a little hand cutter, you know, the kind you literally hold in your hand. It is a two man operation though, you need someone to stand on the far end of the straight-edge as you make the cut, to keep it securely in place.
You would be surprised how easy it is to obtain a good, professional result with such a basic piece of equipment, provided you take a little care.
I have a couple of further questions for UK members:-
Where can I get mount board larger than 40 x 60in?
Does anyone have a decent range of colours in the large (jumbo) size?
John
Posted: Tue 24 Feb, 2004 10:35 pm
by John Ranes II, CPF, GCF
Stafford,
Your Fletcher F-2100, the new F-2200 and many other mount cutters (Keen Cut, Valiani, and C&H) alike are designed to accomodate traditional American "Oversized" mat board of 40x60 inches. These naturally accept the UK standard of 44 inches as well.
Most CMC's like the Wizard, and Wall mounted mat cutters like the Valiani MatPro 150 again typically accept boards up to 150cm or 60 inches.
When cutting matboard (mount board) larger than 60 inches,
John McAfee's suggestion of using hand cutter may sound like a big step backwards, but it will work.
When we were faced with cutting oversized mats, I found one particular hand mat cutter better than most: Alto's EZ mat cutter. This hand cutter is also sould with a simple mat guide that is OPEN ENDED. This unique design allows the framer to cut a distance, then reinsert the blade and continue cutting, theoretically allowing you to cut a mat (mount) of infinite dimensions.
http://www.altosezmat.com/
Check with Lion or Wessex, as these two stockists might have it in their range.
John[/url]
Posted: Wed 25 Feb, 2004 11:25 am
by stafford
dear members all,
thank you for your replies, i will post another reply when i am closer to a sound solution to my problem.
thanks again for taking the time and trouble to reply.
stafford
