Morso Blades
EHT1
- Organisation: World Of Frames
- Interests: Golf
Morso Blades
After shaping the Moros blades several times they become shorter and shorter. Can anyone advice on how short they can go before they need replacing.
- Jonny2morsos
Re: Morso Blades
This is not the definitive answer but I have noticed the more they are sharpened the more frequently the need re-sharpening. So there must come a point whre the cheaper option is to replace rather than keep sending for grinding.
BaBaZa
- Interests: Pubs
Re: Morso Blades
If they are sharpened on a genuine Morso machine then the can be ground untill there is 10mm left between the edge and the copper line.
Twitter #MainlinePolcore
EHT1
- Interests: Golf
Re: Morso Blades
Hi It may be possible on a manual Moros to take them down to 10mm But dose anyone know how far you can grind them down on a EHT
Re: Morso Blades
Mine haven't got a lot smaller in 25 years daily use.
- mikeysaling
Re: Morso Blades
hey prospero - where dya get yours sharpened?
Dev
- Organisation: Kolkata
- Interests: Anything technical
Re: Morso Blades
EHT1,EHT1 wrote:After shaping the Moros blades several times they become shorter and shorter. Can anyone advice on how short they can go before they need replacing.
You can get the blade ground till the width is 59mm.
Dev
framingengineer
- Organisation: Leicestershire
- Interests: Flight simulation, recording, staying as far away from framers as possible........... sorry farmers.
Re: Morso Blades
There is the same limitation as on the manual Morso.
However.......if the blade no longer reaches the sensor you have 2 options.
1 adjust the height of the blade by altering the drawbar at the main cylinder itself or adjust the height of the blade sensor.
I have a bracket (made by Morso) for this purpose.
If I can be of any furher help give me a call
Neil
framingengineer.com
Neil
framingengineer.com
