Having purchased two lengths of moulding I started to cut the fairly chucky square profile only to find the gesso coat chipping badly.
Having only just enough moulding for this fairly large frame, I replaced my Morso blades with a newly sharpened pair, which still did not improve the cut.
I came cross the same problem a while back with another moulding, the distributor changed the manufacturer or specification because the replacement mouldings gesso coating was much thinner and cut perfectly.
I t must be costing some manufacturers a fortune in rejected mouldings, why don’t they do cutting tests with a Morso not Twinhead Mitre Saw before releasing to suppliers.
I’m assume Gesso is the right term for the mica like under-coating that’s applied to the wooden moulding prior to the decorative finish.
Ps. Perhaps mouldings that can only be cut with a mitre saw should be labelled so, some of us cannot afford or have space for an £8000 Double head electric mitre saw..
Thanks for the replacement ******************* Ltd.
