Cutting 150mm Arcadia moulding
Enrique
Hi everybody, any tips in order to cut 10.5cm
Honfleur 202 270 Arcadia moulding in a Morso?
It has taken me a huge amount of time changing
all the time the strings behind the Morso to complete
the cuts.
I am thinking a combination with a hand saw might help?
Looking forward for your wise advise.
ps. wishing you the best in the world cup.
Enrique.
[/img]
the cuts.
Enrique.
[/img]
markw
I've got a Nobex Proman 110 saw and measurement extension from Lion, all mounted onto a long length of wood. I use it for cutting down old antique gesso frames. I also have an old stanley framers vice, because old gesso frames can't be underpinned together either. So far, I have not found anything which the Proman saw can't cope with! Thinks it should do this too!
Cheers,
Mark
P.S. Cutting down old antique frames is a nice little side line, once people get to know you can do it!
Cheers,
Mark
- John
- Site Admin
- Organisation: Tech Support
- Interests: Forums and stuff
Pizmo
absolute framing
markw
The black thingy is a stop, but not much use for framing. The Lion measurement extension system may not be cheap, but I got feed-up with thinking I had got it right only to find I'd cut it wrong. I threw away the black thingy and rod and bought the measurement system. Worth every penny!
Cheers,
Mark
Cheers,
Mark
Pizmo
Thanks everyone .... I guess I will leave it where it is then!
I have one of the measurement systems and it works for me.... the only trouble I have is using the mitre trimmer..... it can sometimes take a while trying to get the pieces exactly the same length. I went into Frameco a couple of weeks ago, (very helpful people), and they have a new mitre trimmer measure which is quite clever.... it means you get exactly the same size lengths every time without having to mess around. Unfortunately a bit too big for my living room that is now looking more and more like a workshop. (hubby grumbling about having to eat his dinner off his lap!) Has anyone got one of these as the measuring system that came with the trimmer is pants.
Pizmo
Pizmo
Enrique
