One of my frames
Posted: Fri 28 Jan, 2011 1:32 pm
Thought I would do a step-by-step of one of my frames. I make alot of frames like this, I don't often use corner decoration on them though, so this one was a little different from the normal stuff.
I am amazed that one of the suppliers like Ashworth and Thompson, Simons, or Arqadia do not offer a pre-finished moulding range in this style (without the corner decoration). It would only need to be 2 sizes of a scooped/moulded profile with 2 or 3 variations on the colour of the scoop and sides. Just two gilded sections with the scoop and sides painted in very neutral colours. I sell loads of this style, often people want a pre-finished version due to costs, but there is nothing available like it! The only company I know about, ever to do anything close is Renaissance. Given the huge selection of moulding finishes surely it would not be difficult to replicate this style! Suppliers, framers, and the public are missing out I think.
The frame is Rose & Hollis A160, once it is joined the mitres are filled and it is sanded all over. Then a 'size' coat of glue is brushed on. Next day 7 coats of gesso are brushed on, this is left for a day or two and then the gesso is sanded smooth. An alternative to the first stages would be to use a pre gessoed moulding. Next 5 coats of red bole are painted on the parts to be gilded.
Then some corner leaves are moulded in two part epoxy putty and glued into the corners. This stuff is a good alternative to traditional compo, its easy to mould and comes out easy with some release spray and can be shaped to the profile without damage to the detail. The inner and outer section are then water gilded, the inner hollow sight edge and all of the outer section are burnished.
Next day the gilding is masked off using removable magic tape, and everything is given a coat of quick drying acrylic/primer undercoat. Then comes the various paint layers, washes, and pigments which are applied over a couple of days:
Hay solid base coat No. 37
Lime white wash No. 1
Cats paw wash No. 240
Light gray wash No. 17
Liming wax on scoop and sides (wiped straight off)
Warm ochre dry pigment (pigments are just brushed on)
Raw sienna light dry pigment
Everest grey pigment
Light rottenstone
That will do for now, next comes the gilding of the corner leaves and finishing off.
Light rottenstone
