Can anyone help? I have a Keencut Laser mountcutter but I am having problems squaring it up. I got some info from some members on how to callibrate it and even a pdf manual on the latest Keencut mountcutter but this is different to mine (obviously)!
I can get it more or less square when I cut mountboard, it measures top and bottom the right measure - great.
Then I go to use it a couple of days later and it is about 2-3mm out again. How do I overcome this?
Under the main measuring bar there are two hexaganal screws that I adjust with an Allen key - I don't know if this is the right thing to do - but a couple of days later it is out of square again.
As I say I have followed the instruction in the newer manual as best I can but it is different as it doesn't have these hexaganal screws in the same place.
Can anyone help? It's a lovely machine as it takes a full size mount board, but it only needs to be a little bit out and on a full size sheet it can be masses out.
Any help would much appreciated.
Regards
Nigel
