Any ideas how to rectify this.
Missing DLL FILE
vapoureyes
Missing DLL FILE
I have an old Toshiba Tecra laptop and each time when windows loads up i get a message saying 'missing MSVCIRT.DLL file.
- John
- Site Admin
- Organisation: Tech Support
- Interests: Forums and stuff
Hi vapoureyes,
Welcome to the forum.
Your topic has been moved to this section as it is more appropriate to your query.
Microsoft has the solution to your problem here.
With any luck it should cure your problem.
HOW Much!?
RobinC
If you google the missing file name you will get a link to http://www.dll-files.com/dllindex/dll-f ... ml?msvcirt and instructions on how to reinstall. I have not tried to replace this file but it has worked with other missing files in the past.
Good Luck,
Robin Carter
Good Luck,
Robin Carter
