Cassese CS810
countrystudio
Organisation: Bristol
Interests: framing
Cassese CS810
Post by countrystudio »
I have just been offered a Cassese CS810 plus a Bambi BF239 compressor at what sounds like a very good price.
£150 for both. Good buy? Any advice or comments?
Re: Cassese CS810
Sounds like a bargain but try them out first if it's local. Mitre a few small pieces of moulding, from very soft wood to oak; take them along and have them joined. Then take the wedges out of the machine and have it go through the motions on a moulding for about 100 times. Oh and make sure there's no noise like a radio on etc and listen for faint hisses at the air joints.
Gesso&Bole
Re: Cassese CS810
Post by Gesso&Bole »
Alistair/Heather
the CS 810 is a fantastic machine, and in its day was THE machine to have. Consequently some of the ones around now are very 'high mileage', or have been cobbled together from different machines.
If you were to buy a second-hand 810 from a reputable company such as Framers equipment in Northampton, they would check over the main, and expensive components, and give you a short guarantee, but they would charge you upwards of £800 + VAT for the underpinner.
If any of the main components need replacing, they will cost way more than £150.
So. Is it a bargain? If its any good, yes. If its a pile of ***p then you will just be buying trouble.
Maybe worth giving Pete a call at Framers Equipment and asking his advice. (www.framersequipment.co.uk)
countrystudio
Interests: framing
Re: Cassese CS810
Thank you for your responses.
I was erring on the side of caution so may pass on this offer.
Much appreciated.
philipsheldon
Organisation: Ashworth & Thompson Ltd
Interests: JUDO / NFFC / CRICKET / REAL ALE ...oh, and Life in general.
Re: Cassese CS810
Post by philipsheldon »
:D
Good morning.
If you are in any doubt at all equipment wise, please don't hesitate in calling the great people at Cassese yourself. Their English is perfect, they couldn't be more helpful & you get an accurate answer. They can be reached on 0033 164 42 49 71.
First rate business, in every way.
If you still require a machine, be that new or old, we can be of help should you require it.
With kind regards,
Phil Sheldon, A & T. ( 0115 ) 964 7507.
There's nothing I can do if it don't get through, blame it on the Pony Express !
There's nothing I can say if it's gone a stray, blame it on the Pony Express !
MITREMAN
Re: Cassese CS810
Post by MITREMAN »
Hi CountryStudio,
£150 could be a good gamble....Compressor could be worth that, Sounds to good to be true, ask about its history
Give it a good look over and a try out as Roboframer said, ALWAYS TRY BEFORE YOU BUY.
Follow Gesso&Boles Advise and give my brother Pete a ring beforehand at Framers Equipment Tel 01604 790810 he may know the history of the machines, he will let you know if he thinks its past its best and if all spares are still availabe as he is a Main Cassese agent.
He can supply all spares and service, but if its uneconormical to replace parts like the cylinder, he will tell you. he also has many secoundhand machines available
Kind regards
Mitreman :D
MITREMAN
