Double and triple mounts....
Posted: Thu 07 Apr, 2011 11:25 pm
I have a problem that hopefully someone will be able to put me on the right track....
I can cut single mounts perfectly every time on my ultimat gold. The problem I have is on some double and triple mounts - the blade is not cutting all the way through the board on some of the cuts. (I cut the 2nd and 3rd boards slightly smaller attach them with ATG and PVA and use the 1st board for measuring).
I have tried altering the depth of the blade but it doesn't give consistent results. Sometimes the blade cuts all the way through, sometimes not. Is there something I am not doing? I join the boards with ATG and PVA and just ATG on the centre cut out. I get the ATG as close to the bevel as I can but there is still a gap - as I don't use a slip mat for the double / triple would this cause the problem?
Sometimes it cuts ok and sometimes it doesn't cut all the way through - I am using the same thickness board so that is not the problem - am ruining a lot of board and wondered if anyone can help with possible solutions.
Many thanks....
Many thanks....
