Kiasu stands
Trinity
Organisation: Trinity Framing
Kiasu stands
Post by Trinity »
I've an odd shaped photo to frame and none of the standard size mdf strut backs will do, and I'm not that keen on them anyway. The kiasu picture in the Lion catologue p104 omits any taping to the back.
Would you normally cut neatly around the kiasu and tape as normal, and generally what's the experienced opinion on these type of fixings. Not everyone of course wants wall mounted so I'd like to get a good feel on this. I have the Kiasus by the way.
Re: Kiasu stands
I think that like the curl up 'n stand system, they're OK for smaller frames. You could use two on a larger frame but the support is still only at the bottom, making the whole thing top-heavy. At least a too-large strutback can be cut down and the support will be more central.
As for sealing the back, if you're using a mount and undermount and seal the glass 'sandwich' with a decent tape like Lineco foil tape, then you won't have to worry about sealing around the fixing.
Trinity
Re: Kiasu stands
Post by Trinity »
Tend to agree, I've used the strut back, trimmed to suit.
Moglet
Organisation: An Urban Myth
Re: Kiasu stands
Post by Moglet »
Wot Robo said, but I like the look of the taped finish on the back. As you proposed in your opening post, Trinity, I used to trim neatly round the fixing. Looked fine. Tesla tape is great, because you can ease it in around the fixing, giving a neater finish.
........Áine JGF SGF FTB
Re: Kiasu stands
What Moggy said. :P
May I recommend 'B' Black tape from Lion. I've used it a lot on standup frames and it is very long-lasting. Slightly pricy, but gives a very classy look. You can either seal the back completely or fold it into the rebate so you can still remove the back but hide all the nastiness that you find on the backs of some mouldings.
