Thick conservation mountboard
- YPF
I have 4 limited edition prints to frame and the customer has selected a thick core mount in Daler's Antique White. I normally use Daler boards but I can't find any of their conservation range that is any thicker than 1.4mm. Have I missed something or can anybody recommend an 'Antique White' thick core conservation from another manufacturer?
Many thanks in advance,
Steve
Steve
Steve
Chief Coffee Drinker
Re: Thick conservation mountboard
Nielsen Bainbridge 8463/8, 8466/8, 8465/8, 8519/8, 8464/8, 8559/8.
- Jonny2morsos
I think Daler do Conservation in 2500mic.
Take a look here:
http://www.daler-rowney.com/en/content/mountboards
From memory the colour choice is limited but should be on the back of the colour chart.
This page from Wessex website would seem to suggest it is available:
http://www.wessexpictures.com/other_dal ... oards.html
Take a look here:
You can make your own double-thick boards with any surface colour you like by pasting two together, I do it regularly.
Just make sure the board you use for the bottom half has a surface paper that is as close to the colour of the core as possible and paste them together back-to-back. I use starch paste applied with a mini-roller and then weight it with a couple of sheets of 6mm glass.
Or if you want you can get nice 'pinstripe' effects, either in the centre of the cut or at the bottom of the cut, by using coloured boards.
- YPF
Jonny2morsos wrote:I think Daler do Conservation in 2500mic.
Robo - I will also give that a try.
Thanks for your time and responses.
Steve
Steve
- Jonny2morsos
Just got back to the office and taken a look at the Daler mountboard selector.
Conservation 2500 mic available in, Antique White 3869, Champagne 3811, Cotton White Ingres 3800, Pale Ivory 3870 & Polar White Ingres 3800.
Looks like you are sorted.
- YPF
Robo, only been able to find black core for this. Which manufacurer should I be looking at?Roboframer wrote:Or if you want you can get nice 'pinstripe' effects, either in the centre of the cut or at the bottom of the cut, by using coloured boards.
I wandered around a Washington Green gallery in Cardiff last week and noticed they use that effect with a blue/grey shade for the pinstripe.
Steve
Steve
It's not the core, it's the surface paper, if you stick two boards together with the bottom one face up you get this ...
But a correction to the quote above, if you put it face down, you wouldn't get the effect at the bottom.
- YPF
Thanks for that Robo, a picture paints a thousand words.
Steve
Steve
Steve
