Black marker for joining Matt Black moulding
Posted: Thu 25 Aug, 2011 7:39 pm
by Bagpuss
Before I join mitred matt black moulding, I colour the top edge with a black marker pen, just so there's no bare wood on the top side when I join the 4 sides. The black marker I use, shows a slightly mauve colouration on the mitre joint, not a real problem but I notice it. I was wondering if anyone can recommend anything other than a glorified black felt tip ?
cheers,
Adam/Bagpuss
Re: Black marker for joining Matt Black moulding
Posted: Thu 25 Aug, 2011 7:44 pm
by Trinity
At various times I've used a black whiteboard marker - has a little ball bearing in it and a pump action to increase / decrease the flow, or black boot polish - I usually go over even a perfect joint with the latter.
Posted: Thu 25 Aug, 2011 7:49 pm
by fineedge
I do it after the joining with a little sponge and black pva paint...wipe afterwards with paper towel - just check beforehand that the matt surface is not affected by the paint
Posted: Thu 25 Aug, 2011 7:56 pm
by Steve Goodall
Hey Baggy - this is a great question!!!
My own colour shift is an orangey brown - I know what you mean & we need something that "dries" & won't "smudge" later - but stays a true black...
Also - boot polish hasn't worked for me - it stays to "fluid"...
Being a "bloke" I was too proud to ask before - but I feel I am in good company now :clap:
BTW - Max at FATG - SORRY - loads of "" again - I can't help it :giggle:
Posted: Thu 25 Aug, 2011 8:02 pm
by Roboframer
You can get dark coloured wood glue but I don't know about black. When there's a problem, which is usually spotted when the join is clamped in my underpinner, I paint the mitres before joining, usually with black acrylic because it's wipes off easily if you get any on the face of the moulding.
Posted: Thu 25 Aug, 2011 8:21 pm
by Jonny2morsos
I use these:
http://www.lionpic.co.uk/product/EDDING ... 381,0.aspx
BTW the ink goes green on contact with water based adhesive :?
Also use the brown ones for dark wood mouldings. For lighter coloured woods Liberon touch up pens are good but they don't last all that long especially if you forget to replace the cap. I have also used some coloured pens for green moulding but can't remember the make but do remember they came from Wessex.
Posted: Fri 26 Aug, 2011 12:04 pm
by Ricky
I used to use Classique filler paste from lion but they don't do it anymore But I reckon this would do the same job http://www.lionpic.co.uk/product/Gilder ... ,1693.aspx Just make your frame as normal then just take a soft cloth & rub into the join then clean off works a treat. :D
Posted: Fri 26 Aug, 2011 12:19 pm
by Graysalchemy
I use OSmo Wood wax finish Transparent. I just wipe a bit into the joint or paint it on before jointing. Wipes of with a matt /satin finish like the moulding. Also use the clear for sealing?waxing barewoods and also the black to finish stained dark barewoods.
Posted: Sat 27 Aug, 2011 7:40 pm
by Bagpuss
Thhanks for all the Top Tips, I quite like the idea of sponging black PVA paint on afterwards, if required, it would probably save me a couple of minutes faffing about with a marker pen before joining :clap:
with thanks,
Adam/Bagpuss
Posted: Mon 29 Aug, 2011 8:51 am
by ComeOnYouReds!
I use a black Edding pen.......from Lion..... it's a water based ink so doesn't leave the purple stain on the moulding. It's easy to wipe off with a paper towel or even a bit of spit on your finger.
The black marker pens that leave the purple stain contain a chemical (can't remember off hand what it's called) and it's a swine to get off.
You can wipe it off however with a smidgen of white spirit.
Posted: Mon 29 Aug, 2011 3:55 pm
by TheHoustonTexican
I learned this from a framer's meeting here in town, not sure if you guys have this brand over there but I'm sure you could easily get them online.
http://www.reuels.com/reuels/media/bl/bl3623.jpg
Prismacolor 90% warm grey has worked best for me, although they have a few other shades that will work almost just as well depending on the shade of black moulding and what type of finish it is.
You'll never get a "purple glow" again and they blend flawlessly with your finger or paper towel.
Posted: Mon 29 Aug, 2011 6:47 pm
by Moglet
HI Bagpuss,
I gave up on using black markers because of the tinted mitre problems. Eventually I found that Liberon's Dark Walnut pen worked better. Also, I kept a piece of crepe bandage handy to wipe off the excess immediately after application of the ink on each mitre face: even a few seconds' delay can lead to tinting problems.
Posted: Tue 30 Aug, 2011 4:10 pm
by Grahame Case
the Berol Colour Fine and colour Broad (Black) pens work well for us -
http://www.internet-ink.co.uk/Other/Ber ... k-S0375350
Posted: Tue 30 Aug, 2011 4:18 pm
by CanvasChris
Good thread... Been using the Chartpak pens and really hate the purple bleed with the black. Other colours not too bad.
Will try all those suggestions.
Posted: Wed 31 Aug, 2011 8:38 am
by Graysalchemy
If you are getting bleed clean it off with lighter fluid should come up ok, however I find the osmo wax you dont get any problems.
Posted: Wed 31 Aug, 2011 8:41 am
by CanvasChris
Guessing bleed is due to the absorbency of the wood. Try so hard not to go over the edge but when you pin it together ... Aargh!!
Smooth Matt is the worse...
Posted: Tue 06 Sep, 2011 10:05 pm
by Ray
Try using the small pots of 'Airfix' paints. You can get matt or gloss.
Buy a small Spitfire while you're at it (but you'll also need blue, white, red, grey!!)
Posted: Tue 06 Sep, 2011 10:22 pm
by CanvasChris
Actually... could have done with some red yesterday... :giggle: :giggle: :giggle:
