Skid Marks
John
Site Admin
Organisation: Tech Support
Interests: Forums and stuff
Skid Marks
Post by John »
If you use a hand held roller to press down prints on to sticky board, you sometimes find that it can mark the paper. Usually this can be cleaned off with an eraser.
But to eliminate the problem, clean the roller by running it over the tacky surface of a scrap piece of the sticky board.
No more skid marks.
Also works on the little follower wheel of a Valliani mountcutter.
Merlin
Organisation: Merlin Mounts
Interests: Aviation
Post by Merlin »
I use the fall out from mounts between the roller and the prints/photographs when I am using PVA, the bevel edges go right up to the edge of the print, so no excess glue gets on the roller either.
But yes, I agree a tack board is good for the Valiani follower wheel.
John GCF
I've never encountered these skid marks, do you use the release paper between the roller and the print, or just roller over the print directly?
Where I first worked as a framer and was trained, the practice was to peel back the release paper and carefully stick-down the print. Then the release paper was replaced over the sticky board and the print, then it could be pressed down with a roller if you wish or more usually pressed down in a dry-mounting press at 60 degrees centigrade, which causes any trapped air to expand and be expelled. It works for me!
Cheers,
Mark
