I'm in urgent need of some large (A0+) size 2mm thick acrylic glazing. Can anyone here do this, or recommend a company who may be able to help? As stated. it's urgent (aren't they all?)
Need 11 sheets 981 x 1328 and 4 sheets 981 x 981
Thanks in advance
Tim
Source for large cut-to-size 2mm thick acrylic/styrene
- Tim
- Organisation: Deepwell Framing
- Interests: Photography, Growing it, Cooking it, Eating it. Sauvignon Blanc. Syrah.
stcstc
Re: Source for large cut-to-size 2mm thick acrylic/styrene
talk to one of your local sign suppliers
or robert hornes or amari plastics
Tim,
Glazing acrylic sheet for those sizes is not an appropriate use of 2mm. It should be thicker.
have you tried http://www.glassandmirror.co.uk/
They do stuff cut to size and seem to have just about everything. And they deliver in their own van.
grahamdown
Hi Tim,
probably not a lot of help as a long way away but i recently had a piece cut to size at 2200mm x 600mm x 3mm from Alluminium and Wood Frame Supplies in London E18 1BY although not cheap at £140.
Alternatively Glass & Mirror (North) in Oldham 0845 456 9972.
Regards,
Graham
Regards,
Graham
- Tim
I think I might go into business supplying this stuff. Thanks all for your help - have now sourced some 3mm acrylic cut to size at a decent price!
Tim
Tim
Abacus
Could you share the details please tim?
Try giving solid glass in goole a ring you probably won't pay more than £10 a sheet for styrene. They also supply acrlylic in varying thicknesses your other option is arqadia's artguard but I don't know if the sheets would accomodate the size you want. It is easy enough to cut with a knife and straight edge or a wall mounted cutter.
