Mounting??Mexican Chamois Leather Artwork
Mossterton
Organisation: Georgian House
Interests: NONE
Post by Mossterton »
Hi everyone- hope you all had a break over the festive time.
My last post was about Leather & here we are again... what is it about me & leather... :twisted:
I have a Mexican Chamois Leather piece which is etched/ engraved? with a design- 86cm x 53cm approx- it's not square.
It has a design round the edge & no seam.
I haven't seen one before but the customer would like it framing so you can see the edges as i agreed would look best if possible.
As it is quite heavy (approx 600g!!) any suggestions on mounting it?
David
Re: Mounting??Mexican Chamois Leather Artwork
Post by David »
It sounds as though this needs floating so you can see the edges, this will then require some mounting board or spacers to lift the glass above the leather.
I would then stitch this to a backing board, if the leather is thick enough you don’t even need to break the front surface, if you do need to come all the way through use a thread that matches the etched/engraved lines and hide the stitches there.
From the description you are going to need a lot of stitches to hold the weight, I’d probably use a double thread as well. Just keep going until it feels stable and lies flat, use sharp needles and a pair of pliers will help.
This is a full sheet of vellum i.e. a whole dried/stretched calfskin - well, trimmed, obviously, cows don't come that shape. It's hanging, and had been for a few hours by a single strip of Japanese tissue attached with starch paste - there's only about 3mm in contact with the vellum.
Regardless of value I would not pierce the visible area with a needle.
To simply float it you could either pass hinges through the mounting board or you could cut the shape out of the mounting board by hand, but slightly smaller, so it would not have to be a neat job. Then attach hinges to the perimeters of the piece, wrap them around that fall out and then fix it back in the hole it came out of.
To float it raised, cut that same shape out of foam board, hinge in the same way and then bond the foam board to the mounting board.
The type of hinge and adhesive I used on the vellum may or may not be suitable for your thing - maybe BEVA and hinges made from mount board surface paper would be better, without being able to touch and feel I wouldn't know.
This is not a conservation thing BTW - it's probably tourist junk like a Hong Kong oil (but I'd not poke a needle through the visible area of one of those either - I'd dry/wet mount it first) just a method that is effective, simple and invisible.
If it happens to also do no damage and is reversible you have my apologies :giggle:
