Framing artwork without mounts
Posted: Sun 08 Jan, 2012 9:53 pm
by pramsay13
I've got a customer who is sure that she doesn't want any mounts.
If I'm going to use glass, what options are there and what looks best?
Are the Frametek spacers available in the UK?
Re: Framing artwork without mounts
Posted: Sun 08 Jan, 2012 9:56 pm
by GeoSpectrum
I had the same recently, and with a pastel :roll: Had to explain what would hapen without a mount. We settled on a spacer, cut from mount board on the keencut narrow enough to be hidden under the rebate.
Posted: Sun 08 Jan, 2012 10:38 pm
by huntvambo
Lion sell Framespace in various sizes. If you have it delivered you have to buy full packs but if you can collect then you can buy any quantity.
Posted: Sun 08 Jan, 2012 10:45 pm
by GeoSpectrum
GeoSpectrum wrote:...We settled on a spacer, cut from mount board on the keencut...
Actually I think I did it by hand. Don't think the keencut could cut it.
Posted: Sun 08 Jan, 2012 11:07 pm
by Vince442
This is a recent frame I did for a watercolour. Again, no mount showing but an inner frame beneath the glass with a thin mount cut and then hidden by the rebate.
Posted: Mon 09 Jan, 2012 2:48 am
The only thing is.... If the item is paper and all the edges are restricted then it is going to go wavy. Spacers or no spacers.
Different matter if the work is on a substantial board.
Still, the customer is always right. :lol:
Posted: Thu 12 Jan, 2012 9:51 pm
by Maihen
you could use the 'hedgehog' method...
cut a mount just slightly smaller than size of artwork and then cut an aperture 3cm in all the way around making sure you use registration marks! Then place the fall out onto back of art work and hinge with gummed acid free hinging tape only sicking 3mm to artwork and leaving rest of strips dry. do this around each side leaving 2-3cm gaps between. then place the mount back over the fall out lining up registration marks and carefully pulling hinging tape through. Tear off more strips of tape and apply water to the whole strip and place over the pieces sticking through the mount.
This will give you a more ridgid piece to work with and will stop it from going wavy.
Hope this helps,
Rachael
