How to frame a Large Laminated map on to 10 mm foam core
gillian01
Organisation: Bygillian Ltd
Interests: picture framing, art , restoration, Photography
Post by gillian01 »
We are looking to frame a large laminated map about 5 ft by 4ft . We need to adhere this to 10 mm foam core. We cannot dry mount this or put it in the hot press. Will have an oak frame round the map but no glass. What would be the best suggestions for this.
GeoSpectrum
Re: How to frame a Large Laminated map on to 10 mm foam core
Post by GeoSpectrum »
is the map currently laminated? and how heavy or flexible is it?
stcstc
Post by stcstc »
Scuff the back of it up to give a key then cold press it to board, I would suggest diabond might be a nicer option, much stiffer and stable
Steve Goodall
Post by Steve Goodall »
suggestion - sub it out - to a pro - with the right kit
