Cigarette / Trade Card Corners
Posted: Sat 21 Jan, 2012 11:50 am
by Ash the Framer
Hi All, I have had a customer come I the shop wanting me to look at his internet bought cigarette card mount and frame, he has tried to place them in the mount and has put glass front and back. The set is 50No. and inevitably they are starting to fall.
What I want to do is use photo corners from the back so the cards sit nicely and don’t fall through and you only see a small plastic triangle in the corners, however I am finding it hard to find corners that are suitable as most stick behind the photo and not on the back of the mount!!
Anyone else had this trouble and if so how did you overcome it?
Any help greatly received.
Ash
Re: Cigarette / Trade Card Corners
Posted: Sat 21 Jan, 2012 7:55 pm
by Merlin
I have searched 'high and low' for these triangle corners with the adhesive on the 'face side' instead of the reverse.
With no luck. Plus they are also self adhesive and can fail in time.
There are some options:
1. Cut two mounts - bevel apertured - so that you overlap the card by 1 - 1.5mm all round. Using 1400 micron board. Sandwiched in between is 500 micron (or less) board cut to the exact size of the card at 90 degrees on the apertures. Using this process you have to make sure that the 'web' of the inside board is firmly fixed to the outer boards.
2. Cut the mounts to exact size with 90 apertures. Using this method you do really need to use glass. If you use acrylic/plexi they could flex or bow outwards allowing for a gap that the cards can slide down.
This topic has been discussed a number of times on the Forum. So try a search for more answers.
Posted: Sat 21 Jan, 2012 9:16 pm
by misterdiy
If the cards are falling between the mount and the glass I suspect the issue is one of not getting the back glass in firm enough. When we sell frames with the mounts we always provide an outer slip mount so that good pressure can put on the glass when fixing in. The problem with doing this on a diy basis is that the customer doesnt have the drivers to put the brads in close to the mount.
Whilst sitting at home typing this I am casting my eye on the 50 set of cars that have been on the wall for the last three years without any movement. The same goes for the sample on the wall in the studio/workshop.
Posted: Sun 22 Jan, 2012 4:33 pm
by technoframer
Find someone with a cmc is the best option, it is then possible to do all sorts of nice designs with curved rows and the like.
Make the cigarette card appertures so that the card will sit in the aperture without falling through. By that I mean when you place the aperture face up, the card should sit perfectly within and just to the edges of the bevel.
Cut one mount face up as normal (the front).
Apply double sided pressure sensitve adhesive (with a release liner) to the back of another sheet of mountboard. Cut another mount (the back) from this, adhesive side up.
Place the cigarette cards in to the back mount, peel off the release paper and stick the front mount to the back mount.
Now you can throw the whole thing down the workshop frisbee style and none of the cigarette cards will fall out.
Posted: Mon 23 Jan, 2012 5:31 pm
by Ash the Framer
Thanks technoframer,
I like the idea of frisbees in the workshop lol
I may just be reading it wrong but can you still see the backs of the trade cards from the back of the frame?
Ash
Posted: Mon 23 Jan, 2012 7:59 pm
by bookmark
Hi, if the mount and cards are between Glass is it not a pressure issue, could spring clips work. May limit moulding because of rebate depth, always worked for me.
Posted: Mon 23 Jan, 2012 10:50 pm
by misterdiy
It is a pressure issue.
Posted: Tue 24 Jan, 2012 1:52 pm
by Steve N
If you use the larger spring clips, the pressure will be better holding the two lots of glass and mount together, the pressure will be nearer the cards rather than at the rebate of the frame, hope that makes sense.
Steve
Posted: Fri 27 Jan, 2012 3:49 pm
by Ash the Framer
Hi All,
thanks for all the replies and advice.
I just took the frame apart and noticed that the internet supplier had suppled a 1.5- 2 mm think styrene to back the cards, this was the issue and i have now changed the styrene for 2mm float and the issue is resolved.
Thanks again for all the advice and if anybody does find the front adhesive photo corners please can you post where you found them.
Ash
