gluing card to foam
CalicoFraming
Organisation: Calico Framing
Interests: Picture framing, fine art
gluing card to foam
Post by CalicoFraming »
Am trying to glue mount card to foam core with pva and a rolled then cutting 6mm spacers but when cut the spacers the card becomes unstuck from the foamcore. Any ideas?
Thanks, calico
CalicoFraming
Re: gluing card to foam
Roller, not rolled. Sorry
If it's just for a spacer I'd use d/s tape. (Not ATG). PVA really needs to dry under pressure to form a good bond.
Gesso&Bole
Post by Gesso&Bole »
Your glue hasn't had time to go off.
I use pva glue, with ATG to hold it until it has gone off. D/S tape would work too
Cut the foamcore spacers first, and stick in the frame using a few bits of Double sided tape (to hold until the glue sets) and a few dabs of PVA . Then cut the card spacers and fit the same way to the foamcore spacers, do as two separate operations, don't try and combined them.
stcstc
Post by stcstc »
i tend to dry mount sheets together, then cut spacers from them
and for colours i dont use a lot i dry mount off cuts
i normally actually use just 2 lots of mountboard though, dont stock 3mm foamcore only 5mm
CalicoFraming
Pressure plus time fixed it in the end, but some interesting alternative approaches for me to try next time. Thanks all!
Calico
