Underpinner help
Underpinner help
My underpinner rubber thing is causing me problems. It keeps popping off the magnet as I'm trying to pin, and I'm worried I end up damaging the wood. I keep glueing it but to no avail. Is it possible to buy a replacement, ideally one with the magnet inside the rubber?
Re: Underpinner help
The 'rubber thing' is a pressure pad! What sort of underpinner do you have? It's not the sort I have because my pressure pad is not attached by a magnet.
Is this one any good anyway? http://www.lionpic.co.uk/product/ADJUST ... 263,0.aspx
strokebloke
- Organisation: Turn Around Artwork
- Interests: Photography, Wood-turning, Wood Carving; Bench Joinery, Cycling:
Precision engineering - Contact:
Maplin's sell button magnets.
Drill an appropriately sized recess into your rubber pad & super-glue the magnet in place
The rubber bit I have just now is not thick enough so is there someone that does a replacement big enough. I seem to remember my old cassesse had quite a bit rubber pad?
Also I can't get it to stay on with glue as it keeps bending / flexing because of different profiles on the mouldings so just separates.
johnwphotography
- Organisation: swadlincote
- Interests: local history, industrial archaeology, landscape and walking
You should be able to purchase a replacement from the spares department at Framers Corner, ask for Ian. They stock both right angle and circular pads.
