I add on another £1 for each additional aperture per mount (i.e. £2 on double mounts). Sometimes I wish I charged more. I was wondering how much others charge and how I compare.
Pricing for multi-aperture mounts
WelshFramer
I'd charge more than that. Probably around £3 for the second opening and £1 - £2 for each additional one after the second.
The first window is pretty straightforward -- just set the measurement on the Ultimat and cut.
The second opening means measuring and marking-up the mat and, in my case, finding the Logan cutter that I prefer to use for multiple openings.
Of course, if I had a CMC...
foxyframer
- Organisation: Hampshire Framing
- Interests: Golf, DIY and baking bread,cakes, biscuits and making chilli jams and various chutneys.
We also add on a £1 for each extra aperture. That on top of the £9.50 chargeable for a 20" x 16" mount for example + v.a.t. Keeping the cut-outs until they fall below say 8"x 10" and become waste. It's surprising how much you can squeeze out of a sheet of mountboard if the cut-outs and off-cuts are stored properly and methodically.
Measure twice - cut once
markw
Don't underestimate the cost of having a cmc - yes cutting multi apps is easy - But you have to set up the mount on the PC - and if its complicated this takes time. You also have the payback cost of an expensive bit of kit. So cutting on the cmc is easy but you are looking to claw back cost so i doubt that sensibly priced extra aperatures are in reality any cheaper to cut.
I charge £1 per extra square/oblong app - this goes up for angled - shaped or embellished cuts depending on set up time.
