Normally on explorer I could put in a postcode in to google and the first thing that came up, on the left, would be a map that I could drag the bloke to any point on to have a nose around.
Now the map comes up, but on the right and when I click on it the yellow 'loading' box stays there forever - I've opened other stuff in a new window to get on with; come back 20 mins later and it's still loading. It don't work anymore! (?)
Went to Chrome - no problem.
IE & Google maps
- IFGL
Re: IE & Google maps
That's why I changed to fire fox, just too many bugs and security problems with IE.
Do you do the windows updates ? if you do see if one was made to IE.
If you don't it may need one.
- Jonny2morsos
No problem with IE here but I don't run the latest version as it is not compatible with XP which we are still running until support stops or we up(?)grade.
