Ive just finished networking my work computers together - I have always hated networking - silly little problems can stop the whole thing working - when you have a mix of wired and wireless this just becomes even more complicated.
The solution to my obvious inexperience was to find a programme that did it for me - network magic did the job - load it and it finds all your pcs - printers routers etc. It shows you a graphic representation of the network - allows you to share files and Printers - and it gives you remote access to selected files. Brilliant software. Free trial at http://www.networkmagic.com/nmlp/linkshare.php
network
- Organisation: dragonframing
- Interests: computers and spending time with kids
Re: network
does that mean you can share dxf files as new to framing many thanks
Re: network
Network magic allows you to network a number of computers within your business. The autocad file format you specify isn't one I am familiar with as far as framing is concerned. The Valiani forum share .plt and .fu2 files - Coreldraw designs can be converted to cad files and exported
so that they can be drawn or cut on a Valiani CMC.
What do you use .dxf files for?
Re: network
hello we have a trucut but you have to use coral first then save in dxf or odf was looking for new designs or any lettering would be a help many thanks i have seen pictures done using a cutter
Re: network
Does anyone thing it be worthwile to set up a web site for designs for cmc machines as i am looking for designs also i have some as well many thanks
Re: network
We have a Valiani forum here - if you look at the forum you will find that you can post designs - we can use Coreldraw designs - but they have to be converted to.plt files for use on the valiani. Would be worth pm,ing John Cooper (Merlin) for his comment.
Re: network
ok thanks thats a great help as can send designs as cdr if that helps
- Organisation: An Urban Myth
Re: network
If you send design files in Corel Presentation Exchange format, they can be a help to people with older versions of Corel (some CDRs are not backwardly compatible with different versions of Draw.)
........Áine JGF SGF FTB
Re: network
thank you i will keep that in mind many thanks
