For the record, this is what I currently do:
1. Measure dry tape across frame and roughly cut to size
2. In turn I run each length through a tub of water, squeezing excess of with fingers and apply to the frame (I was previously using a dispenser but it seemed more trouble than it was worth) - I try to get it to about 1mm from the outside edge of the frame, smoothing it with my hand all along the edge to get rid of bubbles
3. Use razor blade to trip the left and right edges ( this I find problematic, sometimes the tape is too wet and I find it hard to get a clean cut, or in any event getting a straight cut 1mm, and the blade gets gummed up quickly and becomes useless )
4. Then I cut along the inside edge of the rebate to the left and right on the short edges, pressing any overhang against those edges ( this never goes well - if there's already a strip of tape underneath the strip I'm working on, cutting inside the rebate edge is a nightmare - I never get a clean cut and it looks awful ), then I run my fingers along the long edge to tuck the tape into the rebate, smoothing out bubbles as best I can - this bit's not so bad.
5. A general problem is having gummy fingers during all of this - I try to keep them clean, but still seems to be a problem
There needs to be less of this
Any suggestions?
