Oversize perspex / plastic
Posted: Thu 04 Oct, 2012 10:28 pm
by pramsay13
Any ideas who will deliver a single sheet of perspex, I will need approximately 5' x 4'.
It doesn't need to be UV or anything fancy.
And at that size is 2mm okay, or should it be thicker?
Re: Oversize perspex / plastic
Posted: Thu 04 Oct, 2012 10:41 pm
by Roboframer
Far thicker, 6mm would be good, but as far as I'm aware none of our framing suppliers sell it over 3mm unless it's the TruVue Optium stuff and you don't want to know how much a sq m that is.
Try these people http://sheetplastics.co.uk/index.php?route=common/home
Posted: Fri 05 Oct, 2012 1:42 am
by pramsay13
Cheers Robo, link looks good.
Why 6mm for that size? Other than it flexing a bit what's the issue? I take it if there's too much flexing it could pop right out, although there will be nothing pushing against it from the back, possibly only people from the front and then it will bump the object.
Posted: Fri 05 Oct, 2012 9:36 am
by Roboframer
This is 3mm acrylic 1 metre square - it's 'orrible and the wobbly reflections look even worse in real life.
You want something that stays flat and at your size it's MHO that 4mm would be wobbly too - 5mm is available, maybe that would be OK.
Posted: Fri 05 Oct, 2012 10:32 am
by GeoSpectrum
Would wide rebates help? Im planning a large frame with 3mm acrylic and am looking at using a L profile as the basic frame, adding other mouldings in a stacked combination to make it more attractive. The L profile will used upside down and combined with a very wide obeche slip and a strong subframe similar to Prosperos 'Big Jobby' will give degree of stability to the acrylic. I'll have about 30mm of acrylic under the rebate, I'm anticipating that this combined with the wide slip should reduce the deformation of the acrylic.
if not I'll have to think again.
Big Jobby. http://theframersforum.com/viewtopic.ph ... =big+jobby
Large Frame. http://theframersforum.com/viewtopic.ph ... vation+job
Posted: Fri 05 Oct, 2012 11:45 am
The Big Jobby had the acrylic touching the map, so it did tend to stop it flapping. If there was a space, then 6mm would have been better.
The acrylic came from here: http://www.acrylic-online.co.uk/index.php
Posted: Fri 05 Oct, 2012 12:06 pm
by GeoSpectrum
Yep, it was the subframe in Big jobby I was refering to. I'm having to space the acrylic away from the textile in my job hence the wide slip and wide rebate lip in the upper frame to support the acrylic.. I'm still thinking it through and may yet come up with another way of completing the job.
