blades
Posted: Sun 04 Nov, 2012 7:16 pm
by vic
i have a set of blades, with the marks
sharp edge, supercut
and 2 sybols, i think a logo that says 'KK' and 'h'
it appears to be made like morso, with the inlay of an hard metal plate for cutting
on the back side (the side you don't see when mounted) the blades are made thinner for about 1,5 cm
probably for easier sharpening
does anybody knows anything about these?
Re: blades
Posted: Mon 05 Nov, 2012 4:31 pm
by Dev
Dear Vic
It has 2 or 3 mounting holes?
It seems to me like Hansen/Denmark.
Do you have Morso or some other make ?
As far as I know- morso & Hansen blades are interchangeable.
Dev
Re: blades
Posted: Wed 07 Nov, 2012 8:14 pm
by vic
3 holes, seems to fit
they came with a morso machine, but this doesn't mean anything
sleicher knifes also fit, they are thinner, so don't close perfectly
the other way gives some crashes from time to time (you often see this on 2nd hand machines)
i personly work on the morso eht, and sinds last weak, with the morso autogage
