Cutting perspex
Cutting perspex
I need a bit of help as I wrecked nearly 1/2 sheet trying to get a piece.
When I score it with my hand held oil filled cutter it doesn't score enough to snap.
When I cut it with the bench-end guillotine it fractures and splinters both edges (I can put a board on top of it and cut through that as well and then it only fractures and splinters one side and this is how I eventually got the bit I needed).
I have an old fletcher wallmounted cutter that has the double sided cutter with a wheel for glass and a blade for perspex. The blade just seems to catch on the perspex and doesn't slice it.
Any bright ideas / tips?
BaBaZa
- Interests: Pubs
Re: Cutting perspex
Use a Stanley Knife. Lights scores to start with
Twitter #MainlinePolcore
silvercleave
- Organisation: thought I was
Re: Cutting perspex
Use a stanley blade for scoring perspex,
Not a straight blade one or hooked blade but it is shaped to score when pulled towards you, have googl it and don't seem to be able to find one, sure someone will be along and let you know where to purchase one.
Ian
Ian
silvercleave
China shop
- Organisation: Framing shop & Gallery
- Interests: Sport, framing
Re: Cutting perspex
Depends on the thickness you are trying to cut but assuming it is 1.2mm or 2mm thick, you just need to score it with a normal stanley blade and then snap it along the edge of your bench.
Roger
Re: Cutting perspex
Maybe you've got the blade the wrong way up? I don't know about this cutter but the keencut excalibur also has a blade for scoring (not 'slicing') perspex and it's the BACK of the blade's point that is used. It only protrudes from the housing about 1mm. Works fine.pramsay13 wrote: have an old fletcher wallmounted cutter that has the double sided cutter with a wheel for glass and a blade for perspex. The blade just seems to catch on the perspex and doesn't slice it.
Re: Cutting perspex
With my Keencut you turn the head round so that you score with the back of the main blade. It is also best if just a small amount of blade is used so as the blade doesn't dig in or warp. Once it is scored you then snap it along the score line.
- Jonny2morsos
Re: Cutting perspex
I use very little perspex so I now order it cut to size and don't have the hassle of all the offcuts.
easypopsgcf
- Organisation: home
- Interests: cars
Re: Cutting perspex
This is a sure fire way to kill your glass cutter, but it made me LOLpramsay13 wrote: When I score it with my hand held oil filled cutter it doesn't score enough to snap.
Mary
- Organisation: Portra
- Interests: painting
Re: Cutting perspex
I use a Fletcher ScoreMate, it does a great job and has lasted me for yonks http://www.lionpic.co.uk/product/FLETCH ... 886,0.aspx
Re: Cutting perspex
Thanks everyone for the advice. I'll get the fletcher scoremate and give it a go.
And I'm glad I made you laugh easypops - I won't tell you what else I get up to sometimes.
easypopsgcf
- Interests: cars
Re: Cutting perspex
A sharp stanley knife and a decent L square is all you need, not just for perspex but for all board materials you'll ever come up against..........please tell me about the other stuff
Re: Cutting perspex
Ha ha, I might start a new thread. I'm sure I'm not the only one...easypopsgcf wrote:please tell me about the other stuff
