How to lubricate a Morso
CalicoFraming
Organisation: Calico Framing
Interests: Picture framing, fine art
Post by CalicoFraming »
I know there are a number of places where a Morso needs oiling, but does anyone know where exactly and which lubricant to use?
thx
:D
Re: How to lubricate a Morso
Here's the manual, scroll to page F-1 http://www.thepaperframer.com/manuals/M ... tsList.pdf
strokebloke
Precision engineering
Post by strokebloke »
timber & oil ~ adhesives & oil, generally are not compatible.
It's slightly more expensive, but I lube all of my machines with silicone spray.
It doesn't mark the timber and forms a longer lasting film of lube on mechanical moving parts :)
IFGL
Post by IFGL »
I have said many times silicone spray is the framers friend.
strokebloke
:clap: :lol:
CalicoFraming
any particular brand of silicone spray to be recommended?
strokebloke
I use 3 in One
It's relatively priced; it's easily available at most motor shops ( incl. Halfords)
And it works
I'm sure there are other brands out there. Any will probably work as well as the 3 in One
Jack
BaBaZa
Organisation: http://www.mainlinemouldings.com
Interests: Pubs
Post by BaBaZa »
I've been told by a few framers they use 'Back To Black', the stuff that's used on car interiors and bumpers etc
Twitter #MainlinePolcore
strokebloke
I've heard of that being used too ~ and have never heard any adverse reports. So, it's down to price :lol: :lol:
I use Castrol GTX. :lol:
birdman
Organisation: Pelican Picture Framing
Interests: Getting up close and personal with Val
Post by birdman »
Ours was bought new and came covered in a greasy gloop. It hasn't run out yet :-)
Rolf Lawson GCF
pelican-picture-framing
IFGL
Post by IFGL »
3 in 1 silicone spray or halfords own brand, I use both just depends how tight I'mfeeling
strokebloke
A fellow warrior :lol: :yes:
I used to use GT85 which is a teflon lubricant spray. I now use a similar, but cheaper product in a smaller can, which is more convenience because the hardware shop across the road sells it. I also use the same stuff on the CS-88 from time to time.
I'm not very good at remembering to lubricate things at the correct intervals. I just lubricate it when it feels a bit stiff like it's time to give it a shot.
Come on, be honest! Who is there who lubricates their morso every two weeks? Certainly not me, more like every couple of months. Mind you these teflon lubricants last a long time!
I lubricate when I hear a squeak, so, just the foot pedal then!
I know I should do it as per the manual at regular intervals, but my morso; like most I suppose, is not in the middle of the floor, it's against a wall and the back is not easily accessible ... like the foot pedal is.
I used to have to move the Morso to clear out the shavings ... and that would be left until there was so much that the blades wouldn't go all the way down .... and while I had it out I actually would give all the points a quick clean/re-lube. But now I have a 'fire grate' system where I can get all the shavings out from the front and all the moving bits haven't been even looked at since I broke/replaced a spring.
IFGL
Post by IFGL »
every Monday morning all my machines are cleaned and lubricated adjusted if required.
