Hi all!
I need a float supplier in the chesterfield area (or who delivers...) in order to train a mate up to as gooder standard as possible towards his GCF.
I used to get it for less than €20 per sheet (900mm x 1600mm [if I remember right!]), and was under the impression that you can get it much cheaper in the uk.
I had a quote today from my local glass company of £35! I am under the impression that this may be on the steep side...
Any help? I need to get hold of some, probably 6-8 sheets.
2mm Float Glass Supplier Around Chesterfield
Smiffy
- Organisation: Frame
- Interests: Wood, glass & v-nails
Smiffy
Re: 2mm Float Glass Supplier Around Chesterfield
...€20 per sheet in Germany.
- GeoSpectrum
Ask Wessex, I Imagine they deliver in that area. http://www.wessexpictures.com/
- Jonny2morsos
and for around a fiver a sheet 36" x 48" (app 915 x 1220mm) depending on quantity.
