I have recently bought a second hand (but nearly new) minigraf 4, 3 position underpinner. I have seen it working etc and had a go with it before the purchase.
I've now got it set up and running, but I'm having trouble when trying to set where I want the wedges to shoot through (not fussed about the 3rd, but the 1st and 2nd...).
It is different to my old 2 position minigraf, in that the air pressure needs to be on to move the gages on this machine.
What I'm doing...
1. Air flow on
2. Unscrewing position 1 lever (won't move)
3. Nothing else because it won't move!
......any ideas? I'm quite confident that its me monging it as opposed to the machine playing up....
Thanks!
Minigraf 4 (3 position)
Smiffy
- Organisation: Frame
- Interests: Wood, glass & v-nails
- IFGL
Re: Minigraf 4 (3 position)
when in position 1 the air pressure is stopping you move the stop, press the lever/button/pedal , to make it move to position 2 this will allow you to move stop 1.
Smiffy
I figured out that method works. But you can't move it up and down to the desired spot easily - if it's wrong you have to keep guessing until its where it needs to be.
On my old 2 position machine, you just flipped the air off, then you could slide it about to where you want it with ease...
- IFGL
http://www.lionpic.co.uk/product/ALFA-M ... 066,0.aspx
hope that helps.
manual is at the bottom of the page.
hope that helps.
