Framing books
Waspey
Framing books
Post by Waspey »
Wondered if anybody out there could offer any pearls of wisdom when it comes to framing books.
I have framed plenty of football programmes, not a problem! However this is an annual so it is fairly heavy. The front two paged are signed so these need to be on display.
The problem I am having is due to the weight the pages keep falling forward ... Any ideas would be greatly appreciated
P.S What a great forum I can't beleive that I have only just discovered it !!
Tryph
John
Site Admin
Organisation: Tech Support
Interests: Forums and stuff
Post by John »
Hi Waspy, welcome to the forum.
I've never had to do a heavy book so I'm looking forward to the answers that you get to this query.
kev@frames
Interests: 4 or 5 ...
Post by kev@frames »
we have framed some annuals for collectors. when they are to be mounted we usually make up a box out of suitably wide slip (PAR) and hot melt it onto the back of the mount, 2 to 5mm out from the window, seal this internally with acid free tape, then use foamcore or artbak with a liner and point-fix it into the slip.
then a matching slip round the outside of the mount to brace it in the frame and keep it rigid.
Usually works quite well. You just have to wing it a bit as each one can be different.
Merlin
Organisation: Merlin Mounts
Interests: Aviation
Post by Merlin »
Hi Kev
How about a picture of you 'winging' it please
John GCF
kev@frames
Merlin Framers wrote:Hi Kev
will do, next time i do one I'll take pics.
