Rolled up photo
CalicoFraming
Organisation: Calico Framing
Interests: Picture framing, fine art
Rolled up photo
Post by CalicoFraming »
I've got a glossy photo to frame, 30cm x 40 cm. It's been tightly rolled up so I'm wondering about flattening it out a bit before framing .Any suggestions?
:D
Jonny2morsos
Re: Rolled up photo
Post by Jonny2morsos »
Might be worth contacting any photo processing labs in your area to see if they have dry mounting facilities.
sprint95m
Yes.......
Post by sprint95m »
Dry mounting is a good idea, but you can use self adhesive boards instead although I would always use the former.
To flatten curled up prints I place a weight (a box of underpinner wedges) on each corner for a couple of days or more.
IFGL
Re: Rolled up photo
Post by IFGL »
Every order we take is placed flat in folders we make, one of the few advantages of having a 2 week lead time is when they are removed from the folders they are flat.
CalicoFraming
Re: Rolled up photo
I like the idea of putting the photo in a folder - what material would you put next to the photo surface? Mountcard? Tissue? Something else?
IFGL
Re: Rolled up photo
Post by IFGL »
Some have mount board, some have acid free tissue, some are made from the fluted plastic stuff I forget the name of, depends what the Item is. we also make boxs for any stretched canvas we get in, the order form/ticket is then stuck to the front, we have 6 shelves (made from fire doors so quite big) named Monday to Saturday, we then know which shelf it's on from the date on the ticket.
