100 off Box Frames
Posted: Fri 01 Mar, 2013 12:54 pm
by Bagel Framer
Hi all,
Just wanted to get an idea of what you would charge for 50 off each of the box frames attached?
I'm thinking the glass and MDF cut to size by Wessex, the mounts by another source so all I'd do is make the frames and put together.
Ironically the Debenhams prices for the frames are £8.00 each for the small frame and £15.00 each for the bigger frame, so the price would have to be less than that (if it's worth doing for that).
Thanks,
Sean
Re: 100 off Box Frames
Posted: Fri 01 Mar, 2013 1:13 pm
by stcstc
buy them in ready made from someone and made a bit for selling them on
Posted: Fri 01 Mar, 2013 1:27 pm
I'd agree with Steve. Making the same ones as as produced on a factory line is a hard way to make a living.
Posted: Fri 01 Mar, 2013 1:59 pm
by Steve N
If you take a close look at them on the Debenham's website, there is no sign of a miter so they were thick sprayed after joining, also the sizes quoted are the window size of the mount not the frame. You are not going to match the price as I would think £2.50 to £3.00 material cost for the smaller size one, is not going to give you much leeway to make a profit after you factor in your overheads. It's a long rocky road if you try to beat mass produced prices, just give the customer a fair price
Posted: Fri 01 Mar, 2013 2:53 pm
by Bagel Framer
Thanks, yes I am inclined to put some on the price for someone else to make the frames - I have an enquiry out with a local framer on that basis.
Mounts incidentally come to £0.83 and £1.75 each.
Sean
Posted: Fri 01 Mar, 2013 4:06 pm
by stcstc
someone like the readymade picture company or someone who is kitted of for mass production will knock them out cheap to ya
Posted: Sun 03 Mar, 2013 5:50 pm
by silvercleave
Moulded in one so no joint can be seen
It came up before on the forum, have seen them in real life at the store in question
