Just trying to get a leather effect finish on a flat moulding (r&h pw203 Obeche) can't get it looking quite right, saw PB doing it perfectly on a course -at the FATG - didn't write up notes and can't remember how it was done.
Can anyone give a heads up as to what to do pls.
Many thanks.
Leather effect finish
Re: Leather effect finish
What you need to do is build up a slightly uneven texture using thick paint. Wickes Ripple paint with some powder paint mixed in. This will bulk up the paint a bit and also tint it away from the bright white. Natural leather is brown, so a sort of muted brown is probably favourite, but green or red can be done. Shovel it on the moulding and brush it about/stipple it. When dry, sand it smooth to remove any undesirable lumpy parts.
next paint it with a flat coat of similar colour, but in artist's acrylic paint. When that is dry, a thin wash of Burnt Umber+Black. It's a question then of working it around while wet to get the desired effect. Dab it with a paper towel and observe how it settles. A few dabs of thicker brown here and there might help. Complete the finish with a good wax 'n' buff. A bit of experimentation is the thing.
You won't get a perfect facsimile of leather, more a leather look.
- Organisation: Not yet.
- Interests: Off road motorcycling; Youth work; Watching sport - motocross; speedway and rugby mainly.
That's great Prospero thanks. I'll have a go this evening.
- Interests: Picture framing
In my opinion it's about two things - texture, and time. Trial and error. Perfecting your technique may take a while, so test it out before doing it on your actual product.
