Looking for alternative moulding
Posted: Fri 05 Apr, 2013 11:19 am
by birdman
We've been asked to match some frames that we have previously made for a customer unfortunately the moulding has been discontinued by both Arqadia and Simons. This link below shows the Arqadia version and Simons code was 2000/0058.
http://www.arqadia.co.uk/productdetails ... =266101005
I need about 6 metres to make two 16x20 frames. Does anyone know of anything similar from another supplier?
Any help would as always be much appreciated.
Re: Looking for alternative moulding
Posted: Fri 05 Apr, 2013 11:54 am
by Tudor Rose
Have you looked at the Argyll range from Mainline? Might be a good alternative.
Posted: Fri 05 Apr, 2013 11:56 am
by BaBaZa
Posted: Fri 05 Apr, 2013 12:14 pm
by Roboframer
Also A&T 93023.1110 or 93023.1109 - page 38 of their catalogue.
Posted: Fri 05 Apr, 2013 12:40 pm
by birdman
Thank you Tudor Rose and Ricky. Both of the options are narrower at 38 mm but certainly worth looking at. I'll have to ask Ricky to send me a couple of samples
Robo thanks for your suggestions. They are not on that page in my A&T catalogue but that's probably because it's from the dark ages. I'll speak to my local A&T rep, thanks.
Once again the forum provides answers when you need them, thanks guys.
Posted: Fri 05 Apr, 2013 12:55 pm
by Roboframer
You'd probably find it on their website but the catalogue's a PDF so you'd have to scroll for it - easy enough to find the right section first though.
Posted: Fri 05 Apr, 2013 1:12 pm
by birdman
Cheers Robo, good idea. Actually the 158.48 on page 40 might be closer, the shape is certainly nearer. Waiting for the rep to get back to me, thanks.
Posted: Fri 05 Apr, 2013 3:53 pm
by Jonny2morsos
Pescara range from Centrado (01480 4454800) comes in 33, 44 & 78mm widths.
But it is top quality and will be priced much higher.
I used to use some of that range from Arqadia and have a few packs of the mount slip I am now stuck with as I cant get the matching mouldings anymore
Posted: Mon 08 Apr, 2013 2:36 pm
by philipsheldon
Afternoon
Thank you Robo for pointing out our profiles. Looking at the Arqadia profile, I would say that our 93023 section is the nearest.
The 93023.1107 is a bronze, 1109 is a dark silver, and the 1110 is a light gold.
Simon will be in touch soon.
Regards,
Phil.
