Blades ripping moulding
Posted: Fri 28 Feb, 2014 8:05 pm
by Trinity
Any thoughts on this please, morso blades just ravage this soft pine moulding. The blades in the morso were cutting ok but nevertheless I changed for a newly sharpened (LIon) set, but the blades seem to tear the wood out of the mitre and chip the back. Both sets cut harder mouldings fine.
Is there a knack, is it likely to be the moulding, any ideas please
Keith
Re: Blades ripping moulding
Posted: Fri 28 Feb, 2014 8:10 pm
by Graysalchemy
Is the wood soft and spongy? if so that is your problem IMHO, I used to use a cheap aqadia moulding which was like that had to switch to a plastic in the end until a few years ago when they realised the cheap Chinese carp was no good.
Posted: Fri 28 Feb, 2014 8:17 pm
by Trinity
Internally it is Grays, soft without much by way of composition.
Posted: Fri 28 Feb, 2014 8:25 pm
I believe the technical term is 'snotwood'. :?
Posted: Fri 28 Feb, 2014 8:47 pm
by Trinity
Tell you what it's a never to be repeated pita, it'll take some explaining.
Posted: Sat 01 Mar, 2014 1:46 am
by easypopsgcf
Mmmmm Weetabix :lol:
Posted: Sat 01 Mar, 2014 2:38 am
by IFGL
I think you have been extremely lucky to have not come across this rubbish wood before, just get a credit on the stuff and bin it.
Posted: Sat 01 Mar, 2014 7:59 am
by Trinity
"Mudda Fada kindly disregard this letta" (sort of)
You might know the song if your as old as --him over there.
Stick 3 and 4 were ok and the job was completed late last night, I'll see what response I get from my mate behind the counter. You can absorb a lot of stuff though if the end result is good.
Posted: Sat 01 Mar, 2014 8:31 am
You sure that's pine? :roll:
Posted: Sat 01 Mar, 2014 1:02 pm
by JFeig
This same internal mess can also sometimes be seen in foam center board where the foam core has degraded.
Posted: Sat 01 Mar, 2014 5:13 pm
by pramsay13
Yup sometimes seems to be a bad stick or two in with the rest. Seems to be the finish is the only thing holding it all together. As others have said you just need to bin that lot and get a refund.
Posted: Sun 02 Mar, 2014 6:13 pm
by Trinity
Prospero - obeche, stained pine,sorry for the confusion.
Posted: Sun 02 Mar, 2014 6:48 pm
by IFGL
if you don't ask for a refund on the dodgy stuff the supplier won't know there is a problem that needs addressing.
