Dust particles in frame
Posted: Fri 08 May, 2009 9:26 am
by vapoureyes
Any good ideas on getting rid of particles behind the glass after framing as from time to time i have this problem. :head:
Re: Dust particles in frame
Posted: Fri 08 May, 2009 9:44 am
If only. :? Take it all to bits and put it all back together again. :cry:
Are you talking particles of pigment that come off pastel and charcoal drawings? Or just general-purpose detritus?
Posted: Fri 08 May, 2009 3:44 pm
by Bill Henry
vapoureyes wrote:Any good ideas on getting rid of particles behind the glass after framing as from time to time i have this problem. :head:
Ah, the cursed “Flumb” – the scourge of picture framers everywhere. :angry:
Many swear by “canned air” or a pneumatic hose to remove dirt and debris from glass and mats (mounts). I tend to swear at them. I fear that the propellant may contain droplets of moisture to louse up the mats.
I like to use a “camel hair” draftsman's brush to dust off the glass and mounts before fitting the frame. The bristles are soft and won’t scratch or scuff the mat.
Before you seal the frame, view the glass from an angle with a reflected light source. If there are any flumbs trapped beneath the glass, you should be able to see them easily and send them on their way.
If you have problems with pastel dust, you may need to cut your mount with a reverse bevel or construct a float mount so that those particles drop behind the mat when they shed.
Posted: Fri 08 May, 2009 3:59 pm
by Dermot
You can get this from Lion http://www.lionpic.co.uk/(S(gv1thr453o5yji454rqqp0nk))/product/SpeckGRABBER-SGXL-Kit,9140.aspx it is made by Kinetronics
Posted: Fri 08 May, 2009 6:58 pm
by Moglet
Only from time to time? You are blessed! ;) :lol:
To help with your frustration, here's a light-hearted entry on the Flumb from the Framing Oracle: Link
For further amusement, while you're on the Oracle check out the listing for Goobers (a close relative of the Flumb).
I use an air gun running off a compressor. It's one of my favourite (and most useful) bits of kit in the workshop. The guns are cheap as chips (try eBay). If you already have a compressor, I think they're a great additonal piece of equipment (never had the moisture droplet problem described by Bill, but I'm only a small operation. Might be an issue in a busier workshop... :?)
Posted: Fri 08 May, 2009 9:20 pm
"As God is my witness! I will never have flumbs in my frames again........"
Posted: Fri 08 May, 2009 9:53 pm
by markw
I find as i get older and my eye sight fails me - flumbs dont seem to be the problem they once were. My advice, :shock: myopia.
Posted: Fri 08 May, 2009 10:04 pm
by Moglet
markw wrote: My advice, :shock: myopia.
My goodness! My Guinness!! ;)
Posted: Fri 08 May, 2009 10:06 pm
by Moglet
prospero wrote:"As God is my witness! I will never have flumbs in my frames again........
Reminds me of seeing Holly Johnson interviewed many moons ago. When asked about pet ambitions, he replied to the interviewer that he'd love someone to make a movie featuring the line: "Frankie, my dear, I don't give a d@mn!" :)
Posted: Sat 09 May, 2009 8:17 am
by WelshFramer
Isn't the traditional method a peacock feather?
Posted: Sat 09 May, 2009 8:21 am
by markw
whatever turns you on..... :shock:
Posted: Sat 09 May, 2009 1:54 pm
by Moglet
WelshFramer wrote:Isn't the traditional method a peacock feather?
Some people think it's highly unlucky to have peacock feathers in the house. Not heard anything about workshops... ;)
Posted: Sat 09 May, 2009 7:54 pm
by Roboframer
(My red)
Anyone ever done this ........?
Large-ish frame - annoying flumb near the edge - (thinks) hmmm, if I just remove the tape that side and just four or five points, with the frame face up I can bend out the mount(s) backing and get a long thin flat brush in there .....
But you only succeed in pushing it further in, or another flumb appears, and another, but juuuuuust out of reach. So - hmmmmm - just remove one or two more points and I can bend the mounts etc out a bit further and get my brush further in/along.
This continues until you are down to about 5 points and you're STILL trying to poke about without undoing 'it all'
Worst ones though are the ones that appear after final fitting but the glass/mount/backing package has been sealed as well!
They're the special flumbs that are totally clear until after about 10 mins contact with glass. The flumb pervert always stays at least one step ahead of the framer. I just wear earplugs and play Rick Astley records all day - that even keeps the PRS away!
Posted: Sat 09 May, 2009 10:25 pm
by Jonny2morsos
Every time I remove the tape and a few points and give the frame a few taps the flumb disappears..................until I tape it all up again have another look and it has crept back in :head:
So.........I take everything out of the frame and start again at the same time thinking I should have done this the first time. Never learn do we!
John.
Posted: Sun 10 May, 2009 8:04 am
by WelshFramer
Moglet wrote: Some people think it's highly unlucky to have peacock feathers in the house. Not heard anything about workshops... ;)
Think I was wrong about that. I think it should be an ostrich feather.
Posted: Sun 10 May, 2009 8:28 am
by WelshFramer
Normally I tape around the glass/window-mount/art/backing-mount package with P90 tape. I do that with the package glass side up so it's much easier to check for dust as I do it. Once the package is sealed then nothing should get in.
Last week I ran out of P90 (and so did Lion) and I assembled some frames without sealing the package. I had much more trouble with flumbs.
I also use flexible points quite a lot - particularly on pastels or anything where there might be loose bits.
Posted: Tue 12 May, 2009 6:30 pm
by vapoureyes
Thank you all for your titbits,will take all your ideas together to fight the war on dust particles and hope life will be less problematic.
Vapoureyes
Posted: Wed 13 May, 2009 7:46 am
by Pictureman
What we use is the air gun, clean the glass then holding the frame as near upright as possible give it a good blow from top to bottom, try and get a glare on the glass this helps to see anything you have missed, then laying it flat again (gently) the artwork is put in place but do not slide it in....and then the backing board again put in straight down and do not slide it in.....Usually works but not always....Taping the glass and mount together is another good way, and it can be done very quickly, I just use eco tape folding it around glass and mount then cutting the excess off the glass, holding thre blade between thumb and forefinger and also the forefinger runs down the side of the glass and acts as a guide leaving around 3mm of tape on the glass...Jobs done....
Posted: Wed 13 May, 2009 6:25 pm
by Moglet
Pictureman,
Doesn't your "ecotape" method leave you with the potential problem of additional work needed to clean tape adhesive residue off the glass?
I'd like to add a note for any framing newcomers considering the incorporation of sealing mount/pic/undermount sandwiches into their standard workflow for appropriate jobs. I personally would not advocate the use of ecotape for the sealing of frame sandwiches. I use the sandwich taping method on about 90% of what I frame, and I use P90 tape for same. It is possible to apply the tape so that only a 1-2mm overlap on the glass side is needed: takes a little practice at first, but with a little practice, it is quick and easy to do, there is no need for trimming, and therefore no potential risk of the need for additional labour time to clean up tape residue after trimming.
Posted: Thu 28 May, 2009 2:07 pm
by valpendleton
We use that see-through plastic / acetate ? stuff that you get round shirt-collars when you buy a new shirt. You know what I mean? Rub the strips on your head ( I'm assuming you have hair! :wink: ) or on a woolly jumper, to create a bit of static. Slide the strip under the glass & the offending particles attach themselves to it. This can often be done by just removing a few pins, as someone else mentioned earlier & not taking the whole frame apart.
