Morso Blades
Posted: Wed 11 Aug, 2010 7:29 am
by EHT1
After shaping the Moros blades several times they become shorter and shorter. Can anyone advice on how short they can go before they need replacing.
Re: Morso Blades
Posted: Wed 11 Aug, 2010 8:19 am
by Jonny2morsos
This is not the definitive answer but I have noticed the more they are sharpened the more frequently the need re-sharpening. So there must come a point whre the cheaper option is to replace rather than keep sending for grinding.
Re: Morso Blades
Posted: Wed 11 Aug, 2010 8:45 am
by BaBaZa
If they are sharpened on a genuine Morso machine then the can be ground untill there is 10mm left between the edge and the copper line.
Re: Morso Blades
Posted: Wed 11 Aug, 2010 8:56 am
by EHT1
Hi It may be possible on a manual Moros to take them down to 10mm But dose anyone know how far you can grind them down on a EHT
Re: Morso Blades
Posted: Wed 11 Aug, 2010 9:25 am
Mine haven't got a lot smaller in 25 years daily use. :P
Re: Morso Blades
Posted: Wed 11 Aug, 2010 9:27 am
by mikeysaling
hey prospero - where dya get yours sharpened?
Re: Morso Blades
Posted: Wed 11 Aug, 2010 12:31 pm
Check for PM Mikey :)
Re: Morso Blades
Posted: Thu 12 Aug, 2010 1:21 am
by Dev
EHT1 wrote:After shaping the Moros blades several times they become shorter and shorter. Can anyone advice on how short they can go before they need replacing.
EHT1,
You can get the blade ground till the width is 59mm.
Dev
Re: Morso Blades
Posted: Tue 24 Aug, 2010 1:37 pm
by framingengineer
There is the same limitation as on the manual Morso.
However.......if the blade no longer reaches the sensor you have 2 options.
1 adjust the height of the blade by altering the drawbar at the main cylinder itself or adjust the height of the blade sensor.
I have a bracket (made by Morso) for this purpose.
If I can be of any furher help give me a call
Neil
framingengineer.com
